1996 Silverado 5.0 - Various manuals state after removing the power steering pulley there are 3 bolts to remove and then the power steering pump can be lifted out. It doesn't even budge.
I removed another nut on the engine side of the power steering pump (which appears to go through the pump) but it also goes through some other bracket.
I have also removed the AC compressor (I'm going to put a new one in anyway). So the mount that holds the AC compressor and power steering pump has the 4 bolts removed that was keeping the AC compressor in place.
Is there some other bolt(s) that need to be removed to get the power steering pump out?
I need to take it out to replace the power steering pressure line - I don't have tools that can get down in there and remove it first, before taking the pump out.
Any ideas on what other bolt or mounting needs to be removed so I can get the power steering pump out - in order to replace the high pressure line?
Kevin
Kevin
