Transmission
sniderm2011
Is there anything that can be done for a transmission that was drained and now whines really bad?
Yes. Fully warmed. I’ve checked it several several times. After 15 mins of running to over an hour. Still reads above the s curve on stick
Why did you add 5 quarts?
If you are adding transmission fluid after dropping the pan you dont dump it all back in at once.
You add 1 quart less than you think you need, warm up the vehicle to operating temperature by letting it idle, place the transmission in each gear, check the fluid level and add if necessary to bring it up halfway between add and full.
I guess they dont seem to know how to correctly do this.
You refer to the S curve, what about the add and full mark?
Where is the fluid level with respect to the full mark?
