Tranny Problem!!!!
Santos
I have a 2004 Chevy Trailblazer LS with a 6 cyl.engine. I'm having problems with the transsmission. It goes into Reverse fine no problem. But when put in drive it makes a loud grinding sound. It happened as while driving when shifting from 1st to 2nd gear. Before this happened it did slip a little from gear 1to2. Sometimes shifted hard.
It sounds like the problem is internal to the transmission. I assume the fluid level was checked when you first had the slipping problem. Finding a used transmission in good condition would probably be the least expensive route.
