Suburban windows
smcgrath
Hello, new member here.
I'm sure this question has been covered, but I can't seem to find an answer to my exact problem, which is the power windows in my 03 Suburban. Here's what I have:
Driver's window: goes down, but not up.
Front passenger: no problem.
Right rear: Works sometimes, not others.
Left rear: goes down, up sometimes, very slowly.
I understand the motors are an issue, but these all went bad withing a week of each other, which seems strange to me.
Thoughts? I would greatly appreciate any suggestions.
Thanks so much,
Sean.
when you describe these issues are you referring to only the master switch on the drivers door or you experience the same problems when using the individual switches on the doors? If the master switch only I would suspect the master switch. Otherwise you would have to open the doors and apply power directly to the motors to see if they function.
