side mirrors and front doors windows problems
rzkas
Hi? i have 2000 suburban lt 2500 6.0l. both front door windows are not working and both side mirrors are not working. i need help. where should i start and how to fix these problems.
when do i have to use the tow/haul bottom? is there a weight capacity to use it?
should i add an air intake or just buy a flow throw filter and replace the old filter?
100% agreement with Zora on the fuses. If not that, then possibly a bad connection on the switches.
hi? i replaced both front windows regulators today. both front windows works but i am still having a problem with side mirrors. where can i locate the side mirrors fuse
did you look at page 6-57 in the owners manual which is provided above?
yes but it did not say anything about fixing side mirrors that doesn't work
but it does answer your question as to where the fuse is located? did you check the fuse? If the fuse is good you could have a bad switch or a problem with the wire harness in the door or the rubber conduit going from door to frame.
