B bobc30_2 New member Joined Jan 15, 2013 Messages 5 Reaction score 0 Points 0 Age 84 Jan 15, 2013 #1 My service stability came on in dash Help
zora Staff member Joined Apr 24, 2012 Messages 5,518 Reaction score 139 Points 63 Jan 15, 2013 #2 since you dont mention what year, here is a copy of the 2010 owners manual with sections on stability control. Try page 4-68 http://www.extendedgmwarranty.com/owners-manual/chevrolet/2010-Chevrolet-Suburban.pdf
B bobc30_2 New member Joined Jan 15, 2013 Messages 5 Reaction score 0 Points 0 Age 84 Feb 1, 2013 #3 Its a 2004 Chevrolet suburban. Service stability comes on in the dash. each time you start driving. It has no codes.
zora Staff member Joined Apr 24, 2012 Messages 5,518 Reaction score 139 Points 63 Feb 2, 2013 #4 Dont know what codes you are referring to but you need to look at the BCM to check the code not the ECM.
B bobc30_2 New member Joined Jan 15, 2013 Messages 5 Reaction score 0 Points 0 Age 84 Feb 3, 2013 #5 It has no codes. Thanks Bob
zora Staff member Joined Apr 24, 2012 Messages 5,518 Reaction score 139 Points 63 Feb 3, 2013 #6 Then you do not have the correct equipment to check the stability system. A guess would be a bad wheel sensor or the connector going to it, the correct tool would tell you which wheel.
B bobc30_2 New member Joined Jan 15, 2013 Messages 5 Reaction score 0 Points 0 Age 84 Mar 23, 2013 #7 I fond cods C0050 and C0455.Thanks for your help BobC
zora Staff member Joined Apr 24, 2012 Messages 5,518 Reaction score 139 Points 63 Mar 23, 2013 #8 So right rear wheel sensor
B bobc30_2 New member Joined Jan 15, 2013 Messages 5 Reaction score 0 Points 0 Age 84 Mar 29, 2013 #9 Computer said it was right front wheel. So I bought one and installed it. But still says service stability. Now what. Thanks Bob c
zora Staff member Joined Apr 24, 2012 Messages 5,518 Reaction score 139 Points 63 Mar 29, 2013 #10 You stated you had code C0050 thats for the rear. http://engine-codes.com/c0050_chevrolet.html this link references the C0455 code http://www.gm-trucks.com/forums/topic/129653-service-stability-dic-traction-and-abs-light-on/
