firstdog
I had an engine to go bad in my 2003 chevy 4x4 ext. cab 5.3 1500 truck, changed out the engine and trans. 4L60E, now for the problem replaced the safety switch on trans. due breaking the old one trying to get the wiring harness out of switch at the time didn't know you had to apply heat to plug to get the glue to release, now every thing works except it won't got into park, it will only crank in neutral it will get just passed reverse and go to neutral but won't get in park or crank in park, need to know if there is any adjustment that I'm doing wrong, when I installed new switch had trans in neutral, and new switch in neutral so I know I'm close, need to know what I'm doing wrong....Thanks for any help
