remove 96 drivers side door
kortex77
I need to know the best way go remove and replace drivers side door on 96 Chevy suburban. The electric all still works . All the metal inside door is rusted and best option is to just replace. Can some one help me out getting this door off
This is for a 1998 - but it should be the same.
Remove the lower hinge pin retainer.
Remove the lower hinge pin by completing the following steps:
- Use a pair of locking pliers in order to grasp the pin.
- Use a soft-faced hammer in order to drive out the pin.
- Install a bolt through the lower hinges in order to temporarily hold the door in place during the removal of the upper hinge.
Remove the upper hinge pin retainer.
Remove the upper hinge pin.
Remove the bolt from the lower pin hole.
Remove the door from the vehicle.
