Redou
redou
Hello,
My buddy has an A/C problem.
Won't get cold.
96' GMC / Chevy Van 134A system
ENGINE OFF
Gauges say 120 high, 110 low
A / C CONTROLS SET TO MAX or NORMAL, ENGINE IDLING NORMALLY, BLOWER ON
Compressor Clutch not engaging.
Compressor jumped from Battery - now Clutch engages - compressor on
Gauges now say 125 High, 110 low
A / C radiator has air flow
Low side valve shoots out mist when gauges are being attached, I think
system has 134A in it.
ENGINE REVVED UP TO APPROX 2000 RPM
Compressor running (clutch engaged), set to Max or Normal, blower on
A /C radiator has air flow
Gauges say 150 high, 70 low
Still not cold
Compressor seems to be making a high pitched whining noise, but not
very loud, this may be normal, I am not used to this vehicle's sounds.
No bearing rattle from compressor.
Would appreciate any suggestions.
Redou
the compressor not engaging until higher speeds/pressure sounds like the low pressure sensor may be failing but that you still dont get cold at those higher speeds sounds like maybe a blocked system. Does it use an orifice vale that may be blocking flow.
Hello Zora,
Thanx for your reply. I perhaps did not write the post carefully. The compressor clutch engages when I jump it off the battery, so compressor is working at high AND low speeds. I think it has a valve in the system, my friend calls it an 'expansion' valve. I do not know if that is correct wording or not. It seems there is also another valve in the compressor that can affect the gauge readings.
I read elsewhere that:
Low side: HIGH - ( I am getting 70 to 110 on the low side)
High side: LOW - (I am reading 120 to 150 on the high side)
Indicates:
• Compressor valve problem. (different from the Orifice valve)
• Missing orifice tube.
Does this make sense?
I doubt anything is missing because the vehicle owner says system was getting cold previously.
I was hoping someone could interpret the gauge readings
for me.
The charts I can find on the net seem to indicate that a
blocked orifice valve will result in a High reading on the high side whereas I seem to have a Low reading on the high side.
Anyway, thanks for your timely reply.
PS - I cannot figure out how to edit my first post, don't see
any EDIT button.
the edit button is on the bottom of your post right side, depending on screen resolution you may have to shift to right
