rear window defroster
dropdprpls10
have a question here....i have a 07 suburban ltz, on the rear window one of the wires that attaches to the rear window defroster came off... is there a way for me to re attach the wire? it looks like i can just solder it back on.. or am i just buying a new window??
i found the temp. fix with the glue... if anyone has a link to a more permanent fix please post it....
]You should be able to solder it back. The glue will probably not last too long. Seems to me like it would melt.
Make sure that the solder you use will conduct the electricity and give you a good bond. I've seen soldering guns range from 15.00 to 100.00 bucks just in our RadioShack. Shouldn't be too expensive if you don't already have a gun.
