Rear differential on a 1985 Chevy Silverado 1/2 ton (2wd)?
chris m
When i pulled out the pinion shaft to split the axles, the four small gears fell out. When i put everything back together I lined them up so the pinion shaft would fit properly. now when i drive and let off the throttle it makes a grinding sound. My question is if there is a proper way to line up these gears?
