- Nov 11, 2008
- In collaboration with American Expedition Vehicles, Chevrolet releases first-ever Silverado ZR2 Bison special edition designed to bolster the truck’s off-road capability including rocker protection, unique skid plates, custom front bumper and more.
- Also new for select trims in the 2023 model year, the popular 3.0L Duramax Diesel gets fine-tuned for more power with a GM-estimated max horsepower of 305 and max torque of 495 lb-ft.
“Our most recent collaboration with AEV resulted in the much-acclaimed Colorado ZR2 Bison. We’re thrilled to team up again to bring customers Chevrolet’s next chapter of off-road dominance, this time on Silverado,” said Scott Bell, Chevrolet vice president. “The 2023 Silverado ZR2 Bison unlocks the pinnacle of the nameplate’s off-road capability.”
AEV has a strong track record for providing accessories that excel in overland expedition environments. The 2019 Colorado ZR2 Bison quickly became the most popular special edition package offered with the Colorado ZR2. Similar to the Colorado ZR2 Bison development, AEV and GM engineers and designers collaborated on the tooling and design to bring forth the Silverado ZR2 Bison with unique overlanding componentry.
“The Chevrolet Silverado ZR2 Bison is the ultimate half-ton truck for backcountry adventures,” said AEV CEO and Founder Dave Harriton. “The Silverado ZR2 Bison checks all the boxes — robust stamped steel bumpers, complete underbody protection, a factory-tuned off-road suspension, and locking differentials front and rear. We are confident off-road enthusiasts are going to love this truck.”
When compared to the 2022 Silverado ZR2, the Bison special edition is expected to feature improved stats for overlanding adventure. The front approach angle increases to an estimated 32.5 degrees (compared to 31.8 degrees). The departure angle improves to an estimated 23.4 degrees (compared to 23.3 degrees). The trucks are expected to share the same ground clearance at 11.2 inches.
This truck reaches new levels of off-road confidence also in part due to the high-quality steel integrated in the AEV bumpers and underbody protection. The AEV-stamped steel front and rear bumpers are constructed of 3-millimeter-thick steel and are powder and e-coated. The press-hardened steel used for the underbody skid plates is three-and-a-half times stronger than an equivalent cold-stamped high-strength steel plate and provides incredible resistance to underbody damage.
Bolstering the truck’s resume for off-road strength, the Silverado ZR2 Bison comes standard with:
- AEV stamped steel front and rear bumpers with heavy duty recovery points and integrated step pads. The front bumper is compatible with an available winch accessory
- Five unique hot-stamped boron steel skid plates providing protection for the front, rear differential, transfer case and fuel tank
- Steel rocker panel protection
- A three-piece durable steel front bumper with integrated black, vertical front tow hooks
- Exclusive gloss black 18-inch AEV wheels paired with 33-inch Goodyear Wrangler Territory MT tires
- Standard 6.2L V-8 engine with 10-speed automatic transmission delivers 420 horsepower and 460 lb-ft of torque to power through tough terrains
- Multimatic 40-millimeter DSSV spool-valve dampers, which feature:
- Three separate spool valves to control damping
- Three connected chambers for fluid flow
- Uniquely tuned springs that, with the Multimatic dampers, increase maximum front and rear suspension travel, compared to the Silverado Trail Boss
- Front and rear e-lockers
- Specific off-road chassis and suspension calibrations, including Terrain Mode, which allows one-pedal1 rock crawling
Tastefully integrated into the design, Silverado ZR2 Bison customers will enjoy discovering nods to the AEV collaboration throughout the interior and exterior of the truck, including the Bison decal on the side outer box and the AEV badge featured on the front headrests and all-weather floor liners.
The Silverado ZR2 Bison is expected to start production in early 2023 with an MRSP of $78,490 with dealer freight charge included2.
2023 Silverado 3.0L Diesel Duramax Delivers More Power, Capability
Also new for the 2023 model year, the refined second-generation 3.0L inline-six turbo-diesel Duramax is expected to deliver additional power and torque.
This engine is primed to deliver a sizable increase in power and torque for diesel customers. The max power is 305 hp, a 10% increase (277 hp in 22MY), and max torque 495 lb-ft, a 7.6% increase (460 lb-ft in MY22), thanks to several key component upgrades for optimum performance, including:
- New steel pistons with a revised combustion bowl
- Retuned turbo compressor
- New fuel injectors
- Improved temperature control features
This refined diesel engine will be available on Custom Trail Boss, LT, RST, LT Trail Boss, LTZ and High Country, and will continue to be exclusively paired with a 10-speed automatic transmission for retail customers.
The Duramax engine will continue to be assembled at GM’s Flint Engine Operations in Michigan3. and will be available on select trims of the 2023 Silverado 1500 by the end of this year.
