Random noise Brake pedal Vibration
bsud
I getva sporadic noise Brake pedal vibration. It is random and only seems to do it going over rough roads or bumps when Braking. The dealership just put new brakes all way around it and turned rotors or so they said. But it was doing this before they done that, so evidently the Brake Job didn't fix it. Anyone know what this could be?
It sounds like your ABS is engaging. Did you mention the problem when you had them work on the brakes?
Yes and the ABS light and stabilitrak came on and went back off after short time but they said that code was a Wheel sensor which they said was not bad when they checked it. The did a complete brake job front and rear and turned rotors but it's still doing it.
Well obviously they were wrong if you still have the problem and you had a code.
That's what I get for taking it to dealership I guess. If it had not been for the airbag stuff needing fixed I wouldn't have never taken it to dealer. Some stuff I've been reading says it's not really that big a deal if they engage. But I'm not sure I believe that, Seems to me there's a problem if that is happening
