Raise 2001 tahoe idle for better output to pure sinewave inverter
jcy110
Hi,
Is there any way to manually setp up the idle from 500rpm to say 1000 or 1200 so I can get maximum charging amperage out of my alternator?
I only need about 1500W to run baseboard hot water heat, sump pump, internet, laptop, satellite box and small LCD TV. I checked each curent draw with the kilawatt power meter
I have made a "power cart" that consists of (3)12v 125AH batteries wired in parallel that are connected to a 3000w pure sine wave inverter on a heavy duty Costco plastic cart.
For a minimal power outage to run the sump pump I can run off the cart for a few hours, but if a power outage is longer I made provisons using #350 anderson connectors and 4/0 cable to supply power from my Tahoe's alternator via the battery terminals in the truck while the truck is running.
The truck running is quieter and cleaner than a screaming gas generator, and I can disconnect from the cart to fill up the tank then come back and connect again. I can also disconnect the inverter from the battery bank and run it directly from the truck/battery. The inverter only weighs about 20lbs.
Here are a few pics of the setup......any advise on manually raising the idle a little when needed would be appreciated!
I am sure you can increase the idle with any of the programmers available through the obd plug. Many of the power programmers have an idle adjustment in the setup.
