Chunkstyle
- Jan 13, 2011
- Age
- 59
hi guys --
i've got a 1988 suburban that i got used last january. good deal, but lots of little minor stuff that needs attention. the entire time i've owned it, the heater blower has operated at only 1 (fairly slow) speed, with the switch in the 'high' position (doesn't work at all in the other positions). i finally got around to locating & removing the resistor for the motor, planning to replace it so as to have multiple (hopefully faster) speeds available.
to my surprise, the blower still works (at the same slow speed) even with the resistor completely out. is this normal, or is it a sign that the wiring is screwed up somehow? the old resistor doesn't show any obvious damage, so i'm wondering if i've somehow got messed-up wiring and the resistor's not the problem. don't want to waste the $20 on a new one if it's not the issue.
any input?
thank you!
drew joseph
any input?
thank you!
drew joseph
