Puzzle
Country40
I have a 2008 Aveo 5 with the 5 speed manual transmission. Just replaced the clutch pressure plate and the throw out bearing. And put in a new slave cylinder. Car drove fine for a few hours. Now it only tries to move but will not. Any help is appreciated. Thank you.
With the engine running in neutral can you shift into 1st gear?
If you can, are you saying it stalls as you release the clutch?
If so it sounds like the gear selector has engaged two gears, possibly 1st and reverse.
