Putting Cadillac Escalade seats in the base suburban
Mlsteel
I have a 2008 3/4 LS suburban. This suburban was a base suburban with the front bench seat. I have purchased a set of quad buckets out of a 2008 Cadillac Escalade after installing the seats I realize that the plug for the seats and airbag or different. how do you hook up the seats. The heater part of the seat function does not bother me it's just the electric motor that runs the seat forward and backwards that I'm trying to get accomplished has anybody done this
I'm not sure why you'ld want to go thru this much trouble but since you are, you need to figure out which harness connector pins supply power and which seat pins need that power. Then you'll need to fab some interface cable between the 2. Don't cut your connectors or it will make it hard to go back to the original setup.
