Problems shifting gears on 2000 Chevy Silverado?
confused
Hi, my boyfriend has a 2000 Chevy Silverado (automatic) with 140,000 miles on it, and lately it's been having problems switching gears. It'll switch gears later than it's supposed to, sometimes we even have to lift off the gas for a second to help it switch. Sometimes it won't even switch into 5th gear (but sometimes it does). Is this a problem with the transmission, or the computer, or some kind of an electrical problem? Would putting in some transmission fluid help? The check engine light hasn't come on at all. Any advice on this at all?
Checking the transmission fluid level would be a great place to start. Flushing the transmission and replacing the fluid would be a good idea, too. If that doesn't fix it, there could be a bad solenoid or shift relay.
I had the same problem. Its the transmission. The gears are slipping, and the entire transmission will need to be redone/overhauled. You can continue driving it, but it will gradually get worse. So my advice is to take it to a transmission place and let them pull the trans out and fix it back up. Will probably need newer parts. Good Luck!
