power windows not functioning correctly
motorgrunt
i have a 2008 1500 WT ext cab. power windows quit working properly. they go up all the time but they do not go down. i have to press the switches up and down multiple times to get the two back windows to go down. the front works usually. the windows will usually go down if i use the switch at each door but if i use the switch on the driver side door it takes multiple tries to get them to work.
i told Chevy about the issue but they would not work on it because the windows worked when they tried them. now it is out of warranty and the issue is worse than ever.
i looked for info on how to access the switches, but everything i find is not 100% applicable to the WT package. the WT package is different from the others.
any advice on the cause of the issue or how to access the switches is greatly appreciated.
Semper Fi
Semper Fi
motorgrunt,
Thank you for taking the time to post your concern and questions. How many miles do you currently have on the vehicle? Can you please message me directly with your VIN and the name of your dealer? I look forward to your response. Thank you for your service! I look forward to your response.
Christina
GM Customer Service
