Have no idea why your car would have 3 ported vacuum switches. Ported vacuum refers to the advance mechanism on the distributor. It is used for emissions purposes as opposed to manifold vacuum. The ported systems are controlled by one switch that is temperature controlled. So which switch does the vacuum line from the distributor connect to, that is the ported vacuum switch. Any other switches you see have nothing to do with ported vacuum. Do you have the 1978 Chasis Service manual, it has a section on emission controls with diagrams. Another thought is if you dont need to have it set up original just run the vacuum line from the distributor to a port on the carburetor or intake manifold that has vaccuum at both idle and at higher speeds.
