passlock or fuel pump
likiuki
How can you be certain which issue you have? 2001 malibu was idling in parking lot, then just died. Turning key to on position i hear no fuel pump. When key is off and turned to on position, theft system light is solid color and goes off, and sometimes is solid and stays on when all others go off. If passlock has been activated is that why i do not hear the fuel pump?
possible it will disable it, we have had a few issues with the ignition lock cylinders going bad setting false theft codes.
