When stopped and in gear I see the oil pressure drop, warning comes on.
Replaced the oil pump
Replaced the Oil Pickup O-Ring
Replaced the Oil Pressure Sender
Found a small crack in the pan so that was replaced also.
The old oil pan was pretty damn clean, even low in the sump, oil looked good too.
Gauge will go to about 30PSI when driving and the RPS are upward of 1500-2000 but when stopped at a light, in gear, idle around 750RPM, Oil pressure warning comes on and appears to be at about 10PSI.
No difference in engine performance, no noises. Not burning oil, plugs were clean, no smoke.
I am thinking maybe a clogged journal or a problem with the gauge? When these gauges go bad, they usually are pegged or at 0 all the time, so I am not sure that is it.
I am going to try and blow some air down the passage for the oil sending unit but hope someone had some other ideas.
2006 Tahoe 5.3 150K Miles.
