NO HEAT
HUNTERMAGNUM
I have heat in the front of my suburban for a few minuets and then it turns cold. Have heat in rear and works great all the time.
Is there a fix for this?
Can't tell what year you have but have you ever flushed the front core?
start the vehicle, set the temperature to hot, turn off the vehicle, pull the HVAC fuse, wait 3 minutes, reinstall the fuse, start the truck, do not touch the temperature controls, see if heat comes out after a few minutes.
Beyond that it could be the controller or the blend door actuator.
A tech tool would have to be used to determine the cause.
