Need Help With Code P06DE 2014 Malibu LS
johndegrazier
The code only pops up if going 65 mph in 6th gear after the car is warmed up. I can drive any speed after it automatically shifts until I reach 65 mph. I can drive for miles doing 60 mph upto 64 mph. but the second I go 65 mph or above and only in 6th gear it throws the code. I just replaced the oil pressure sensor switch. Same problem.
Only throws code in 6th gear at 65 mph to 70 mph. If I am driving 65 mph and go up a hill and it drops to 5th to keep me at 65 mph, the code does not come up. I have noticed it mostly comes up when coasting at 65 mph to 70 mph on a flat or slight down grade. Need help bad because I am an Uber driver and this is my job.
Please help.
John
I know what the code is. I just don't know what would cause this at only 65 mph and above in 6th gear. Can drive 64 mph all day and it will not throw code. Only when 65 and above in 6th gear.
Is that the condition under which you see the lowest engine speed?
I am having this same issue- I drive for about 45 minutes and then bang the code comes on , usually when I’m around 65mph
