my chevy suburban idles high in park like 1300-1500 rpm, it idles fine...
Chieftain
...when in drive.? 1999 chevy suburban 148,000k on speedometer, odometer stopped working around the time engine idle problem started, it only runs high when its in park or nuetral. i changed the IAC valve, the sparkplugs, and the fuel injectors. still have a check engine light on saying the idle is too high. what do i do? i dont want to take it to the dealer
Sounds to me like you have a vacuum problem. Check your hoses for cracks, tears, and the plastic junctions for breakage. Hope it helps.
