My Chevy Silverado 1500 is having a fluctuation rpm. Its very slight but
zach m
annoying, how do i fix it.? The year is 2000 and its a v6 4.3L. It revs up a little past 1000rpm and idles at bout 750. No irregularity in temperature or oil pressure. However recently i have felt less pick up in the accelerator.(related?)
Thanks
It could be the tps ( throttle position censer) or just a sparkplug miss firing. When was the last time you changed the plugs.
It sounds like a plug firing then not.
Is the check engine light on?
If so having it scaned might tell you more information as to what is causing the problum.
