My 1995 camaro z28 appears to have a misfire. Help?
knoc_u_out
I notice that the car all of the sudden sstarted tu run rough. I had experienced a similar thing before as a result from a loose wire with the max air but thats fine. now i replaced the wires and spark plugs but its still the same. I have been told it could be the distributor cap. Please advise!
i had this same problem with my 95 trans am, it was the actual coil wire that was corroded. the lt1s have a bad problem with that. hope this helps
