My 02 Chevy Malibu will not start;it stalls as if it had no gas but is sitting...
Hortencia
...on a full tank? I drove it around all day yesterday it started perfectly fine drove fine. I attempted to start it this morning it started but only stayed on for 2 minutes then shut off; after this I couldn't get it to turn back on it would only stall and it sounds like the car has no gas but i filled up before i came home so that is not possible.
my thoughts have already been mentioned, so i'll just say, I agree with your first two responders.
One other possibility could be a vacuum leak at the Fuel Pressure Regulator.
You may have gotten some bad gas with water in it , if so change the fuel filter and add some HEET into the gas tank, you can find this at the auto parts store , it helps break the water down so you can get rid of the water. Also check the fuel pump relay your fuel pump.
