Malibu Service Traction/Service ESC
Imax310
I have a 2009 Malibu that has had an issue with the Service Traction and Service ESC notices being displayed. Seems that this has become a pretty common issue with the 2008-2011 Malibu as well as the HHR. It results in the vehicle stalling, loss of power steering and ABS. Not good when doing 70 on the expressway. Anyone have this issue and a solution?
You need the error code to be read which will point out which of the sensors or other components is causing the issue.
I had those same problems with an Equinox I had and it wound up being the EGR valve. How they're connected is beyond me. Have you run the computer codes on it? If not, do that and post them here.
