Lumina 3.1, year 1997 ABS light is on
Dean65
Hello.
Where could the problem, I bought the car and that light was already be alight.
The sensors have been changed, Where could the problem be, Where to find fault? Sorry my bad english.
if you are sure the sensors have been changed look at the wire harness going to the sensors or find a shop that can scan ABS codes.
Dean65
I actually changed the front sensors, and i check wires next.
Where i can buy fault code reader, because this Plug has is only 2 pins?
are you sure this is a 1997? is the 10th digit in the VIN a S?
