I need to change the drivers side headlight in my 2002 Chevy Malibu.?
Sarah
Im not able to simply unscrew the bulb from the inside of the hood i have to take the whole headlight out to get to it but i need further direction! any helpful tips appreciated! Thanks! :)
At the top of the light housing, there are two L shaped black thingies, one on either side of the back of the housing. Slide them gently up, this will release the ball fixtures that are mounted to the frame. Then the bulb housing will lift out. Turn squeeze the little springy plastic thing attached to the light bulb holder, and turn gently to the left I believe, from the back. Use a clean napkin or dry kleenex to install the new bulb. then reverse the procedure to reinstall, make sure the black plastic thingies capture the little ball things to hold the housing in the proper location. No tools needed. Good luck.
