joshscott84
- Jun 11, 2012
- Age
- 40
2002 Malibu LS 3.1 was running fine. I pull up to house turn off car, come out few minutes later to leave and car won't start. When I roll key forward I get all dash indicator lights for 2-5 secs then just oil, battery, and check engine stay lit after. Car cranks but no fire. All fuses and relays have been checked in both the interior as well as the engine compartment fuse blocks. I have no pressure in the fuel lines and where you could clearing hear the fuel pump priming before, you no longer can. Ordinarilly I would just say it is the fuel pump, but what is making not jump to dropping my tank so fast is the fact that I’m not receiving any voltage to the rear fuel pump connectors. Also when checking for voltage I grounded to the body to make sure it wasn’t an issue with a ground. Plus I find it hard to believe the fuel pump just died without any signs and regardless I should have 12 volts to the fuel pump with key in the ON position whether pump is bad or not. Never had an issue with the passlock before and the light is not now nor has ever been blinking. 68k miles, new battery, as well non-factory key. One weird thing is on several and very random occasions I’ve turn the car off and walked away and the car has honked the horn and locked the doors as if I used a keyless entry, for which I do not have.
I have tried the relearn process in the 10 minute increment and the 30 minute increments, both with 1,2, and 3 cycles. no luck
pulled the ignition switch and lock cylinder from the car. I have a haynes guide that has a diagram for continuity testing the switch but the connector displayed does not look like mine. So in curiosity I disassembled the ignition switch further only to find the contact pads underneath all burnt up minus 1 or 2. I'll attach pictures below. Not sure is this is normal or if the burns even make a difference but cleaning pads had no effect after reinstall.
