...honest Abe Junkyard.? Had all the tranny fluids drained and replaced with a new tranny filter too. I was told to place Qty. 4 quarts of Dextron 3 in the filler and then start the pickup and run for about 5 seconds so the pump can push the fluid into the torque converter. Then added another Qty. 4 quarts again and repeted process again. Anyway, after Qty. 8 quarts my tranny dip stick showed over fill - What happened with this procedure. I was told the pickup should hold to Qty. 15 quarts for fill. Should I continue to add more??? Started the pickup many time and checked dip-stick, still over-fill. Does the pump moving the fluid to the torque convertor work slow
