I have a 2003 Chevy suburban 1500?
LIZA
When I take my foot off the gas peddle the idle goes down and the car turns off. If I turn a corner the car turns off. When I am at stop sign the car muffles a little and then the car turns off. When I press on the gas to go from a stop sign, I here a tap sound only at that time like 2 pieces of metal tap only once. I have to drive it with the gas and break at the same time to keep the idle high.
well you have to start with the simple things first, Because a 2003 is relatively new, I suggest you go to your local mechanic and tell them your problem and let them do an engine diagnostic. The reason is this your vehicle has several computers, and what your mechanic can do, is plug his diagnostic computer into your suburban, and your vehicle will tell the mechanics computer where the problem is located. And then the mechanic can fix it.
This is the best way. it sounds like it may be something simple, have you done anything different recently, like buy cheap gas? because my suburban was picky, it liked the good expensive super I was running from chevron. If some guy accidntally put regular in, I could tell it ran worse. This can be something as simple as a tune up, to a tank of bad gas. best of luck, take it to the mechanic.
