I have a 01 Chevy silverado 4.8l and i seen a video on youtube regarding the EGR
bavow1982
valve the guy cut a can? and made as a gasket he covered the two holes from the EGR valve, is it a temp fix or does it run better that way?
If he defeated the EGR valve by closing its passage, the car more than likely will not pass a smog test, reguardless of any performance increase. When they check the ERG as part of the smog test to verify its proper operation, the non-functioning status will be obvious. That will be a guaranteed failure, so don't forget to get a new EGR gasket so you can restore the proper condition before the smog test. I wouldn't be surprized if one side of the valve passage fills up solid with carbon- and that stuff is hard as a rock- when you do that little cheat.
It will probably set a code on your OBD and make your check engine light come on.
