How to remove the passenger side door panel from a 97 chevy suburban?
Phillip
I'm trying to change the passenger side mirror and it is an electrical one
that has a connection inside the door panel. I cannot figure out how
to take the door panel off, and I do not want to break it. Thanks for any help you can lend. Phil
You should have a couple of screws in the arm rest and maybe one behind the inside handle. If you take a flat head screw driver and slide it between the panel and the door and gently pull out on the screw driver it will pop away from the door it is held on by plastic pop out screws after you get it loose grab it by the sides and wiggle it up and it should come out. There maybe a screw up by the mirror on the inside that removes a piece of plastic also. Inside the door when the panel is off you will find 2 or 3 10 mm bolts take them off and unplug the mirror and install new one. If any of the pop out screws stay on the door you can pull them out by sliding a pair of wire cutters under the round head and pull them out and attach them back to the panel. Just take your time once you pop a couple out you can see how it is held on best bet is to start at the bottom.
Chevrolet Suburban 2500 Brake Master Cylinder
hello,
Try this site....http://www.kwmuth.com/techsupport/pdfs/21001190.pdf
if you are looking for auto parts then you have to visit [FONT="Book
Antiqua"]theautopartsshop.com[/FONT]
, you will find all your need.
Buy Low Price Chevrolet Suburban 2500 Wheel Hub Assembly, Clutch Kit, Brake Rotor, headlights, Brake Caliper, shock Absorber, Door Mirror, Strut Assembly, Alternator, Exhaust Manifold at theautopartsshop.com
Chevrolet Suburban 2500 Brake Pads
Chevrolet Suburban 2500 Oxygen Sensor
