Hi, have a 70 corvette and brake pedal goes all the way to the floor as many times as you can pump it. I have checked the master cylinder it has good pressure. There are no visual signs of leaks at all anywhere on the calipers or any of the lines... I have check every inch and none of the line are wet anywhere. It seems that there is still air getting into the system.... but I have no idea where and if that is it? Help please...
Thanks Dave
Thanks Dave
