How expensive is it to replace a Camaro Power Window Motor?
David P
Does anyone have any idea of how much it would cost to have the driver's side power window motor replaced on a 2000 Camaro? I have replaced the switch and checked the wiring. Once in a while it will move a few inches, but then takes forever to get it back up. Any hints?
The motor itself will cost about 70 at a local parts house or you can buy the motor/regulator for about 200. If you replace it yourself you need a good drill pit and a punch to pop out the factory rivots if it has never been changed before. You will have the separate the motor from the regulator if you are just changing that piece. It is not that hard of a job if you have patience but you be careful of the glass breaking when you take it lose from the regulator. Tape it to the top of the door to hold if you are alone.
