How do l prepare my 96 corvette for cold weather l am from florida but l will be
Pinky
traveling to missouri.? the temperature there are suppose to be in the single digits should l take it to a shop to let them look over it to make for sure it will make the trip or just add antifreeze to it myself.
Make sure your anti-freeze is suitable for the temp your going into. Proper mix should give you protection down to 20 below sometimes lower. This will be adequate for just about anywhere. Here in the north in the winter we run 5W30, a light weight oil helps the engine turn over better. Make sure you have real windshield wash in, water will freeze in that reservoir. Other than that you shouldn't need to do anything else.
