First open the hood, look on the passenger side of the car where the belt fits, on most malibu models they used a motor mount right where the belt fits, if this is the case then you need to get a floor jack and place under the oil pan, raise the jack putting a little pressure on it (the engine should raise slightly, but don't go to extremes), there should be 3 to 4 bolts on the mount, remove them slowly and carefully, after removing the bolts raise jack more til the engine and mount clears, take a 3/8 drive ratchet and place it in the idler pulley (it's spring loaded, be careful, it can pinch fingers, it hurts real bad) find out which way the pulley will release tension, while releasing tension remove the belt. When removing the belt pay close attention to the way it goes on, when replacing the belt put the belt on all pulleys except the smooth pulley, using the ratchet to move the idler pulley just enough to have room to place the belt on the smooth pulley, look over the way it is on the pulleys to make sure alignment is straight and correct, no over hang on any pulley is allowed it will cause the new belt to wear out prematurely, replace the motor mount in its proper place and slowly, very slowly lower the jack, reinstall the bolts (keep pressure on jack don't just remove yet), slowly tighten all bolts until tight, remove jack and check bolts again, start engine and make sure it runs o.ok.
