How do I change the tail light on a 2005 Chevy Cobalt LT?
potus98
The 2005 Chevy Cobalt LT has a single, triangular tail lamp assembly on each rear corner of the vehicle. (Not the more common pair of circular lights on other models.)
Opening the trunk reveals two screws attaching the tail lamp assembly to the car. Removing the two screws allows the assembly to wiggle a little bit, but the assembly cannot be pulled away from the car to disconnect the wiring harness or access the bulbs.
The Pioneer sub woofer limits how far I can pull the trunk carpet wall back, but I have felt for any other retention clips, screws, or wire harnesses. I cannot find anything else to disconnect.
I have gradually increased my pulling force with no success. I have tried sliding the assembly in different directions to un-lock any slide-and-lock style retainers with no success. I have tried removing the passenger-side tail light assembly, but have the same problem.
