Help
jcgrandpa14
In stalled a new lock cylinder and did all the programming instructions and it don't start no crank It started be for that what could it be it's a 2004 with out alarm
Why did you change the lock cylinder?
If you read page 2-17 of your owners manual the Passlock system disables fuel not cranking.
Did you disconnect the car battery?
Did you drain the battery?
Using a multimeter what is the battery voltage?
