Hello:
I had to replace a wheel bearing in the front rotor of my 90 4X4 3/4 ton suburban
I"m having trouble getting the snap ring in
In the diagram from my repair manual it shows the snap ring goes just after the locking nut and then the locking hub.
I tried this because there is a notch there, but it's a real sloppy fit.
When I removed the rotor, I had to take the snap ring off first, then pulled out the locking hub, nuts ....etc
Now when I go to put things together, I'm having a hard time installing the snap ring on the shaft after the hub is in.
Anyone have any tips, ideas?
Thanks Mel
Thanks Mel
