I love Suburbans but I just bought a 99 5.7L that was difficult to get started. It would run awesome once it was going but then it would hard start even if it was warm sometimes. The check engine light is on and the scan shows 1345 error (crankshaft to camshaft position correlation fault).
by the way already tested fuel pressure it holds very well at 55-60 psi.
ok so I changed the crankshaft position sensor thinking that would do the trick but no effect.
Then I assumed the distributor was amiss so I grabbed on to it to see if it was loose. It was kind of loose and it actually rotated without adjusting the bolt with that horseshoe collar thing under it.
Now it starts like crap and runs like crap. It doesn't even idle well, it kind of falters. Something is way off and Im pretty much stuck. I tried putting the distributor back in the exact same position but it didn't help, I guess I wasn't accurate enough.
Help please. Thank you so much. -Brad.
