Occasionally I get heat blow out of drivers side vents when AC is on. Passenger side blows cold air.
This is no fun when it's 110 outside.
Drivers side hot/cold slider control has no effect.
You have an issue with a blend door actuator. The vehicle has to be hooked up to a diagnostic system to determine what codes are present. The problem is they may not be present when the system is working correctly.
