Header bolts
veronanova
What's the best way to remove the last header bolt on the passenger side? Heater box, etc. is in the way. Cannot get a socket on it due to the pipe.
you cannt get an open end wrench on it? you have tried from under the car also?
No on the open end wrench... And yes have tried from under the car. Header tubes are in the way. Put these pipes on about 4 - 5 years ago and cannot remember how I got to that back bolt. Do remember that it was a pain then however!
is the problem the socket wont fit or the extension is blocked by the pipe? have you tried a universal joint on the socket?
