Garage door opener doesn’t work with engine running
Zorad1000
1999 Suburban. So it has taken me about a year to figure out that the problem with my garage door opener is actually a problem with my Suburban. What happens is , the door opener works fine as long as the engine isn’t running but when I start the engine it won’t close or open the door, then I can turn off the engine and it will work fine again. But wait there’s more...after driving for a while and coming home the remote will open the door just fine with the engine running.
I suspect there is some kind of interference coming from the alternator or the ignition system. I forgot to mention that the door opener is not a factory installed option on my vehicle , it is a hand held remote. Before getting this far I tried a new battery for the remote, I swapped remotes with my car and I bought a new remote for the Suburban and I got a new battery for that remote. Nothing solved the problem. Any help is greatly appreciated.
Have you tried moving the antenna on the garage door motor?
Zorad1000
No I don’t remember doing that. But before I discovered that I could turn off the engine to get it to work I would leave the engine running and get out of the truck and walk over to the door , stick my arm into the garage and I’d have to press the button several to get the door to close .
Zorad1000
So I just looked at the antenna it is hanging as close to straight down as it can . Looks like I took the rear plastic cover off and straightened out the antenna at some point.
Try having it go to left or right to see if it gets better reception.
In my case I have Sears and found the remotes fail, I have a collection of them that either dont work or are sporadic, and LiftMaster makes a better replacement.
Zorad1000
Ok thanks for the help.
