Engine Decode
lesrsz28
I have an engine i have been trying to decode and could use some help. Front #s T082IS, Back of block 8782870 and i believe a date code 32463 or G2463. Any help will be appreciated. Thanks Les
The T0821S is Tonawanda assembly plant August 21st and the 'S' is a 327 power glide.
G2463 is July 24th 1963
The 8782870 is the casting number
lesrsz28
Ok Here is my question the 1 is an I also the S is for a 1962 327 but block cast date is 63 could the T082IS code be a 1964 IS 327 instead of an S 327?
I would expect T0802IS not T082IS
Why would a July 24, 63 casting not be used until Aug 64?
lesrsz28
I would put a pic on here but I don't see how. I agree with you on the date but the code is T082iS as per pic. i is capital in the code number?
Are you sure somebody didn't restamp the block?
Does the pad look like it was machined and restamped?
The digits line up ?
lesrsz28
Yes they all look fine maybe I could send a pic in a email? lesdowns@msn.com I was able to upload the pics on Chevelle Tech maybe you can see them there?
The lower left of the reply box has 'attach files'
