flyboh
- Apr 10, 2022
If anyone on the Forum has used the Holley Sniper Stealth EFI system on a C2/3 Corvette, can you please share with me the electrical source you used for the pink wire from the throttle body and the yellow wire from the in-tank fuel pump? As both need designated/unrestricted 12 volts during crank and run operation, I can't find a source except for the ignition switch wire that feeds the resistor/coil which can't carry any more load as I have Petronix ignition. I'm almost done but don't know much about electrical wiring except for checking voltage and would greatly appreciate any input from those of you who do know a lot more than I do. Thanks in advance,
