Drivers Side Headlight/blinker/DRL Issue
isaacnjenna
I have had an on going issue with my drivers side blinker and headlight not working in my 2007 LS when the lights are on "Auto." If you turn the lights off manually, the blinker works as it should.
Found out the harness above the radiator fried the relay loop and one other wire. Replaced the loop and wire and it worked for 6 months and went out again. Replace the relay loop once again and it still doesn't work. Now what?
The bulb is good (did not touch new bulb with skin and used grease), not the fuse, etc. I'M AT A LOSS!!
Any ideas are greatly appreciated.
check all the grounds for corrosion or partially broken or loose
